71Scamper
Mopar runs thru my veins!
Anyone know where I can buy a pinion preload sleeve for a 742 case?
Why do you want to sell the 742 housing just because it doesn't use a solid shim? In essence the solid spacer that is present in a 741 and you buy to install in a 489 is made onto the pinion so in the end it's no different from the others mechanically (other than the bearings it uses) and a cone style sure grip will fit just the same because the pinion has nothing to do with the sure grip
Oh no, I get what your saying, I'm just thinking it'll be easier to sell both housings and just buy one from Cass. My wife says i can't buy one from Cass until I sell what I have lol. Just trying to get the most bang for my buck. I have 2 compete 741' cases, one being a cone sure grip, I have a 742 case with caps and adjusters, and a spare 8.75 housing and axles off a b-body but with the perches at stock a-body width. I wanted to make a compete axle and sell the spare parts too. I figured the 742 would be the way to go and have more interest in.
