AdamR
Big Member
Hi guys, My 75 Dart has A/C and a smog pump, all of which was not hooked up. I removed the smog pump and started pulling the A/C compressor. Can I pull the compressor bracket or is the power steering pump bolted to it ?
I also want to remove the remainder of the smog equipment, egr and charcoal canister to clean up the engine bay. Any thing I need to do beside plug the ports ?
