Yes, there are several different widths; The As, The early Bs, the Late B & Es, The Cs, and D series pick-ups .There may be more,IDK
Only the As have the sbp( 4" small bolt pattern).All the rest have the lbp( 4.5" large bolt pattern).
The As are 43.5" c/c( center to center of the perchs).Early Bs can be installed by spreading the springs a hair(IIRC they are around an inch wider, c/c).
You didnt say what body or engine you have.Ima guessing its a 73up Dart 318. You should know that the little 8.25 can take quite a licking.So if its a mild 318, you might just slam a SG into that go have fun. Its been said, that the bigger sbms will break it sooner or later, especially on slicks, if they hook.On the street with a teener, I ran the heck out of one, and never killed it.
If you are thinking of tracking your car more than occasionally, this is all moot though,as you will be wanting to fit tall slicks, on wide wheels. This will require custom sbp wheels, or off-the-shelf lbp 15s. And so you will need to have the diff narrowed and custom lbp axles built. In this case just about any old set-up will work for you.
If you go this route, I suggest you buy your wheel and tires first. Then rip all the old stuff out to get it out of the way. Set your new assembled wheel/tires in the tubs,center them up, drop the car down to ride height, and re-center. Then measure the flange to flange distance, and send your rear end out for adjusting.
Of course,you can do it the other way, but IMO it never seems to fit right if you do.And if it ends up too wide, youre almost screwed. If its too narrow, you can always space it out. So measure very, very, carefully. I narrowed mine to fit off-the-shelf, 4.5" bs 15" wheels,of which I had several to chose from.And I liked the look of a 15 x 10 al slot with that bs.
If you are only going to track it a time or two, then a stock-width set-up will do, with custom back-spaced wheels.
