That's the tone ring, not needed take it off the new assy.Its 8.25. The bearings will no doubt need changed but I cant figure out why the carrier in rubbing. It has small teeth around the perimeter of the carrier that rub the housing. The actual gear seems fine and all numbers point me to an 8.25. Need a different carrier I guess. Must be something a little different about this one. Pinion and pinion bearing fits fine.
