[SOLD] 8 3/4 pumpkin 1820657 3.54 gears "741"
VDART
Shulte Ks
I have this 8 3/4 pumpkin for sale-- gears look good -- it is the 657 style housing -- with 3.54 gears single spinner-- $75 + shipping.
located in wichita Ks 67209
item will weigh approx 80lbs -- Thanks Lawrence
below is the 8 3/4 article with info about the rear--
The 8-3/4" axle was available in three basic types. The types are differentiated by the pinion stem diameter....1-3/8", 1-3/4", 1-7/8". The choice of axle pinion assembly was determined based on the application. Differential bearing setting (ie. backlash ) is set with threaded adjusters on all carriers. All 8-3/4" carrier assemblies can be identified externally by the casting numbers.
1-3/8" small stem pinion (aka. '741')
Carrier casting numbers: 1820657 (1957-1964), 2070741 (1964-1972).
This assembly was typically used in low weight/low horsepower applications through low weight/medium horsepower and high weight/low horsepower applications.
will sell just the gears & pinion for $100 net shipped to the us only--- this should work for the 741 case also. thanks
