8 3/4 vs Dana pinion length..same??
pettybludart
Ontario,Canada
I,m wondering if the pinion length is the same for 8 3/4 vs Dana?Will changes need to be made on the length of my driveshaft...longer,shorter.Thanks for any input.:-D
They are the same length. My old drive shaft from the 8.75 days fit.
Hey Scott. The Dana uses a different pinion. The clamps are U bolt type. Length of driveshaft won't need to be changed, as cuda20 said.
You going to a Dana? Thats cool. You'll be glad you did.
Yep Bill,I,ve had my share of rearend issues,breaking off perches,twisting Strange axels,driveshaft issues,burning out sure-grips,etc..etc..I,m hoping to put a Dana in and end problems for awhile anyway.LOL.MoparFest is going to be a blast this year,but bring your own steaks LMAO.
Everything I've read says the yoke to axle centerline of a Dana vs. an 8-3/4 is a little over an inch different necessitating drive shaft length modification.
Here's a link to a chart on Moparts that says the Dana yoke to axle centerline is longer than an 8-3/4
http://www.moparts.org/Tech/Archive/axle/5.html
If it's correct the driveshaft would need to be 1.12" shorter for a Dana.
shorter.
That's from the axle centerline to yoke distance making the dana 60 yoke closer to the transmission
