OO, I just thought of something; My brother in law came to me once with his brandy new Mack conventional semi-tractor, that had a running issue, that nobody seemed to be able to solve. Well I didn't know chit about that truck.But we went for a roadtest,anyway. Well once he got into the higher gears, this truck would go into this bucking mode where the hood would just start to go up and down and rest of the truck too. This was the first year for the Macks to get a RoadRanger transmission. It was the only tranny that could take the 1200 ftlbs that big engine was putting down.
Anyway, it seemed to me to be fuel related cuz empty, that big old motor was barely being taxed. And you know diesels run WFO all the time, only adding fuel for the load. That means his right foot was directly attached to the injector pump,sorta.
So I looked down at his big fat right foot, and low and behold, it was dancing on the pedal! Well the whole cab was dancing except his air-ride suspension seat which was just floating.So the thought came to me; was the foot dancing cuz the cab was dancing, or was the cab dancing cuz the foot was?
So I said take your foot off the gas and put it back on. And the dancing stopped. And then it restarted.
Now I had just converted his 9 speed to a 13 speed by adding a splitter box on the rear. This required shortening the drive shaft.And this behavior only started after the Auxiliary box went on. So the thought occurred to me that the driveshaft was not properly balanced and was shaking the frame which found it's way into the cab, and started his foot a-dancing.
Well my tight-azz B-i-l didn't want to hear that. He was thinking I screwed up. But the A-box was working perfectly and he really loved it. So after a bit, he relented, and sent the D-shaft out again. Sure enough, it was out of balance, and after the rebalance no more shaking. I tell you what, I was his hero for a long time after.
Now I'm not suggesting that your driveshaft is shaking your carb or anything at all like that. But an 850 has pretty big airvalves, so it doesn't take much butterfly action with some combos for the engine to get excited.
I can imagine a big engine,in a light chassis,with a manual trans,and race gears,with a floor-mounted gas-pedal, and a light duty return spring, doing something like that. LOL. I said imagine......
