EL5DEMON340
Got this off a member a few years ago its a 9036s 850cfm quad it is a remanufactured super nice carb! After i received it i went ahead and put a new kit in it anyway, new choke pull off, reglued the main wells, debured and smothed out any casting flaws. the choke plate and rod over the secondary's were removed for more flow (should be in the 900/910cfm range). Then consulted with a couple well known t-quad builders for jetting input for my 360 with about 400hp the squirters were opened to .032 from .028, primary jet went to .101 and secondary went to .154, door drop at .100, 2110 rods. Carb ran very nice when pulled off two summers ago, i run a 6 pack now. Im pretty sure it would not need a rebuild since i drained all the gas out, but not 100% i did soak the carb gaskets so they should come apart without tearing if you want to disassemble and blow out.
Parts included is the choke system, 1/4" spacer with gaskets and longer fuel line. please ask any questions you may have, can be picked up in Aurora ,IL $225 OBO + shipping Thanks FABO
