98 Caravan Strut Tower Repair
longarm
Car sold back to original owners
central ohio
I want to repair the driver side strut tower on a 98 Caravan.
It has a wheelchair lift in it and I'd like to safely repair it so
it can be put back in service.
I'd like to replace the entire tower but am having no luck finding
an aftermarket source.
I can find the caps, but no towers.
Does someone know of a supplier?
Thanks Carl
Pretty sure you're gonna be SOL without getting a salvage yard piece of going the dealership route.
All I could ever source was the caps.
I am on "The Chrysler Minivan Fan Club" forum. You should probably post your question there. There are some very knowledgeable members.
That is a common problem with those minivans. Especially the driver's side where the battery is gets corroded faster.
My ex had that happen on one of hers and a local body shop here fabbed some metal up to reinforce it and it lasted until she traded it in...
There are aftermarket repair kits available...
It will cost around $500 - $750 to fix....
