kdsmith07
this housing is 52 1/2" wide and the perches are at 43".it's a 742 case with oe 3.23 gears and clutch type sure grip.case has all new bearings and seal with new clutches.has the large strap type yoke.has stock sbp axles w/3"studs.brakes are 10x1.75 with good bell drums.needs the brake lines cut and bent.asking 825.00 and pick up only in ga.30052 unless you can arrange shipping.pm me if interested.thanks,kent
