FOR SALE A very clean (not pitted up) 8 3/4 a-body housing with new metal brake lines, new brake block and hose, 1 pair of small bolt axles, 1 pair of small bolt axles drilled to big bolt 4.5 pattern with green bearings installed and a pair of C body cutter axles, 2 set of backing plates, and 2 pair of flared 10 inch drums... Also, there are 2 center sections, a 2.94 open 471 case and a 4.10 clutch type suregrip 489 case... Price for the housing, backing plates and small bolts axles is $350.00... It will need to be picked up... I am in lower central Pa 17301...
