Is Passon still in business? With policies like his, he should be bankrupt!
He needs his *** kicked is what he needs.
I'm all for the 'kick his *** and return the trans, rectally" train of thought. Like in the movies where you show up with Zeke from the loading docks, who owes you big favor, and Zeke smacks the guy over the head with a frying pan until he coughs up the dough.
Unfortunately, real life is a bit different. When the guy is 5 states away from you, it's hard to put your hands on him. It's also hard to get blood out of a turnip....chances are extremely good the money you gave him 2 years ago is long, long gone. It's not like you're gonna dip in to the trust fund his granny left him. You could report him to the authorities, but let's not lose sight of the fact that we now live in a couuntry where if you want a new TV, you can protest one from Target with no consequences. In fact, you can blatantly commit federal crimes and no one will bother pursuing you. So I doubt Sergeant Ludowski in gonna go chase down some guy over a 4th gear issue.
Most of all....few of us have the time on our hands to chase some retard around the country. We have jobs, families, and lots of other stuff to do every day. I sure can't tell my company I'll be out for 7 days while I go to Seattle to plant a car bomb.
That's the beauty of forums like this one....word gets around and the single best way to hurt the guy is to make sure everyone knows.
They use a lath as a test bedGFI stated many times they bench test the trans, but added it does not bring it to a high enough, or very high, rpm.
well that must be fun to run through the gearsThey use a lath as a test bed
Yes, I seriously did consider the OD.
In fact, jtkaaa07 had one, or was it two, with the shifter, and they were both cast iron.
It had the bellhousing on it, but it was for a small block. He had a friend with a big block bell for it that wasn't ready to let it go, iirc the bb bells actually came in trucks. I'm not sure how readily available the bb bells are, but I couldn't find another one.
I found 2 trans locally, within 4 hrs drive, both with shifters, one cast, one aluminum, both with sb bells, $500 and $900.
An OD and the associated parts, probable rebuild or at a minimum refresh, was beginning to balloon in $ and time.
I've also found concerns about the amount of power, hp or torque, both were referred to, that an OD can take. I didn't take this part very far, so I'm not convinced either way, but it's a 383 that's up there and the plan is to go a little more.
There is a company that sells the gear set to convert an A833 to OD, or a complete OD, however it's sold by you know who and made by you know the other who. In addition, there was the fbbo member who just got one, questioned a 2nd gear noise, and was told nothing to see here. I'm no expert, but that doesn't sound correct.
I have one of these OD transmissions and it sounds like an old truck. After three trips, including a smashed crate, to GFI and one to Passons and more money from me no one can fix it
Completely absolutely 100% believable.After three trips, including a smashed crate, to GFI and one to Passons and more money from me no one can fix it
There is much more to the 855 story
The other product is garbage and requires cutting. More like the Tremic transmissions are awesome but they do require cutting.There is much more to the 855 story but it is not my place to explain it in here.
It's not the best situation for a product that really improvises the old car's driveability and bolts in directly without fuss. The other product is garbage and requires cutting.
I am unable to determine based on the posts who owes who, if the op is owed money it is not abundantly clear as to why.
If anyone out there has significant funds you can buy out the the project and fix it's woes. If you don't want an 855 try 3.23's or 2.94's with a 2.66 1st gear ratio 4 sp
Why not? If you have more knowledge, spill it!There is much more to the 855 story but it is not my place to explain it in here.
What "other product"? Gear Vendors? hardly garbage, but not the best solution for everyone either.It's not the best situation for a product that really improvises the old car's driveability and bolts in directly without fuss. The other product is garbage and requires cutting.
Read the whole thread, it's pretty clear to everyone else. He spent six grand, received a transmission that won't stay in 4th, and got the run around for a year.I am unable to determine based on the posts who owes who, if the op is owed money it is not abundantly clear as to why.
.If anyone out there has significant funds you can buy out the the project and fix it's woes
I had 3.23's behind an A833 years ago (mild 383), and it worked fine.If you don't want an 855 try 3.23's or 2.94's with a 2.66 1st gear ratio 4 sp
Did you read anything above?Anyone got any info on these? Thinking of getting one.
I think he was being facetious (maybe)Did you read anything above?
one more thing, what's with the torx screws and washers on the ends of the fork handle pins? What purpose do they serve?
I wasn’t sure I saw someone asking about one recently on here.I think he was being facetious (maybe)![]()
