LOL......I'm guessing that he's just having fun trolling.
that comes under the category of 'just because you can, doesn't mean you should' lol.Outstanding, all who said scrap it, in effect issued a challenge.
I was thinking the same brass brazing rod low heat then file and shape etc. But is it worth it? Depends on how rare I suppose and orange paint would cover the repair. Ih ave an old square bore intake I have to check out with similar issues not cracks but bolt hole issues.There's no distortion on the intake port crack, or other shift that would require machining. I'm thinking about about what CH 1 II said about brazing it. I had good luck with that before. I have practically nothing in it.
Oh damn, I was hoping it is worse than warped, after all, I have a reputation to live up to.
Yes, but only if You leave a pile of metal & abrasive wheel powder big enough to trip & fall flat on Your face over, not that there's anything wrong with that......i have a 76 318 2bbl motor, can i bolt this on with a 750dp and make 400hp?
i have headers and DUI distributor, if that helps.
ah, so you've seen my youtube channel. excellent.Yes, but only if You leave a pile of metal & abrasive wheel powder big enough to trip & fall flat on Your face over, not that there's anything wrong with that......
They don't cost much, I would buy another one. I have seen these for $100.00 or so. Sometime less.Got this in a swap
lots of cracks
Wasn't too interested till I found out it's 68-70
340.
Isn't this the best 340 manifold or was the 71 better
Looks like someone attempted a jb weld patch on the back of the manifold
I have never seen a manifold crack this extensively
Not concerned that it will appear patched
Was this one of the manifolds Mopar copied or vice versa
It looks like a 70' intake. Any 340 intake will do but this one, I would toss. They are not that difficult to come by, for around $100.00, more or less.Got this in a swap
lots of cracks
340.
been kinda slow on FABO, just tryin to stir things up a bit LOL
This forum is funny to read sometimes.
That manifold is indeed scrap, but it can be used to help with practicing welding or porting skills maybe.
Barn door stopand even after you're done practicing it'll still be a good wall hanger![]()
Why are all of you making fun of a boat anchor? They have a useful place. I call the manifold a "conversational piece". I have a connecting rod for one, that looks like a pretzel, out of a 340 I blew up. The cylinder looks like a corning ware dish that was dropped on a tile floor.Best boat anchor in all of Florida!!
