bkbond12
Old ones need lovin too..
Hello Everyone,
So I'm finally going to install my air compressor. I know that run length, piping diameter, and everything can affect air pressure etc, but I don't know how badly, because I've never had a nice air compressor.
I'm going to to run either 1/2" or 3/4" line and use a ball valve shortly after it exits the compressor. From there, I will be installing a filter and possibly a hose reel or coupler port. I will then pipe it over my door frame with a catch drop and ball valve on the other side. I will be installing two coupler ports and a 'T' that runs overhead to a hose reel in the center of my pole barn. I will continue the original horizontal run and end just past my hoist with another reel.
I'm probably going to be using black pipe because it's cheaper than copper and it's sturdy. Will the setup work well, or will I need to change anything? I can place the air compressor on the other end if it would work better. Let me know guys. Thanks.
