fishy68
Tyr Fryr's Inc.
I need a couple insulators that are used on most all round or square back alternators.
1st one I need is the one that insulates the "hot" terminal from the case of the alternator. Just need the outside one so the alternator doesn't even have to de disassembled. Just take the 1/4" nut off and it's the little white insulator behind it.
2nd one I need is the insulator that is also on the "hot" terminal but this one is the one that is more like a protector in that it shrouds the "hot" terminal bolt so you don't accidentally short it to ground when working on the car. I believe they were also used on almost all round or square back alternators. I know that's not a great description but it's the best way I can think to describe it.
If anyone has either or both of these please PM me.
