coair73x
This is sounding like less of a direct bolt in Radiator.Oh yeah and adapter bushing for the lower hose...
A little grinding and drilling is all that is needed. very little. A quality piece for little money. Keeps my big block under 200 on a 90 degree day with high stall and steep gear.This is sounding like less of a direct bolt in Radiator.
That is nice to know. I think I will wait till winter to jump into this job. I hope to see some photos of the ecp 22 inch in some cars with original shroud.I didn't have to any drilling or grinding on the 67 fastback at all. just a little work on the radiator
I just had to open up some of the bolt holes on the radiator. Very close to lining up but not quite. Hose bushing on the lower only.grinding on the radiator its self or radiator support? I have a numbers matching 1970 Duster 340 4 speed so not interested in drilling radiator support. The adapter bushing? Is it needed for all hoses? I have a mild built 40 over 360 in the car now with a 727. I had it out today in 95 degree weather and it runs 192 if it idles in traffic.
Yes I have looked at that miloden pump. I understand the ECP is 2 row at one inch and that should work fine. I am not getting the 26 inch. The 22 should bolt in stock holes and use my shroud. When I get around to.do this I will post pictures on a new thread about the install.
For now I have no plans to. I am either going to have my original cleaned when I change the antifreeze or try the ECP and put a new water pump on. Car runs plenty cool in fall and spring. I would prefer the car to run 180 or so in summer months.I would not change a thing on your cooling setup if your car runs that cool in 95* weather. Looks to me like you have a good tune and cooling setup.
