coffeedart67
Have searched for this and couldn't find the answer. Have the motor mount brackets painted and ready to install, but not sure which side of the block the go on. Have figured out from other threads that the brackets go on the back of the block ears, correct, with nuts on the outside. One bracket is straight while the other has an offset, which is passenger side and which is drivers side. I have a service manual on cd but it just shows 2 straight brackets.
Thanks
Aaron
Oops almost forgot, 67 Dodge Dart with 273, and biscuit mounts.
Thanks
Aaron
