Keyways on the cranks are in the same spot. The changes are in the timing covers and balancers. Atleast for me, the easiest way to mark the balancer for the timing cover, or mark both to be able to read them is to establish true TDC using a piston stop, then mark one or both. You can then add before or after marks as needed based on the cover's scale.
