straightlinespeed
Sometimes I pretend to be normal
I have a similar issue as gunmetal72, but I think mine is from the front end.
Here is my situation.
Driving about 60 down the road and my car will start to hum or vibrate, but more of a hum. It continues as your speed up. If you let off at 60 and let it coast it will go away. If you accelerate it starts up again.
I bought this car last fall and before I stripped it down for a rebuild it was this same way.
I had the rear end apart over the winter and it was clean and had a good wear pattern on the ring and pinion. Everything seemed tight and no issue.
I also noticed that the front wheel bearings were way to loose, to the point the wheel would wobble on the bearing! I tightened and adjusted them properly.
I believe its the front and the bearings are wore because of the loose bearings.
Looking for help with this before I start throwing money into it.
