clhyer
- Joined
- Feb 24, 2007
- Messages
- 3,734
- Reaction score
- 320
So, I needed to replace our kitchen range. An older drop in Roper model that is probably 26+ years old. I lucked out and found a Kenmore model, also made by Roper that fit into the same hole. Had I purchased new, I was faced with making the hole larger.
Anyhow, an installation manual for the Kenmore & Roper is not available; so I am a little puzzled by the wiring.
The house wiring consists of two large insulated black wires, and one large bare aluminum wire.
Both stoves have a black, white, red & bare copper wire.
The old stove was wired black to black, Cu to Al; and the white and red wires where tied together to the second black wire.
When I look at wiring instructions for newer stoves, it looks like the white and Cu wire go to ground. But, I have no instructions for this particular stove. Any help will be appreciated.
Thanks,
C
Thanks,
C
