I know its not a a body, but other forums have neen useless, and you guys are awesome.
2010 jeep grand cherokee. 5.7
Started throwing cam sensor codes.
I cleared it once, and cam And crank then popped.
I did read to just replace both sensors, as one will offset the other.
Replaced both.
NOW...it cranks for 15 full seconds. Finally fires and kicks crank signal code, and traction control light comes on.
So...i "fixed" it...and made it worst...
I originally contemplated doing timing chain...but hell...now im pretty sure its in limp mode.
Short of putting the old sensors back in, or spraying off the contacts in the weatherpacks to pray its something as dumb as a pin not commecting...
Any ideas? Bout to have it towed... thanks in advance
Replaced both.
