67Dart273
Now that Radio$h*t is down for the count for many people, I'm thinking of
1....At least buying a bunch of appropriate gauge / sender test resistors. These would imitate the factory test box, so you can use the destructions in the shop manuals, for low, med, high readings
2.....Maybe building a repop factory gauge / sender test box, the C-3826, a first try of which I built for myself. That would be considered a "test mule" IE what I sell might be quite different, although, same in function.
http://www.forabodiesonly.com/mopar/showthread.php?t=179517
If you are interested, I'll have to research a cheap box and small switch. Resistors are cheap. Someone recently posted a 'heck of a good shot of the original, here
