Any low 11’s 6 - Pack cars on here ??
EL5DEMON340
Aurora,IL
Thinking of upping my game, not interested in hearing about how I’ll make more power with a 4bbl, had many 4bbl/two plane / single plane combos, my ported intake with mechanical carbs pulls just as hard if not harder with my current setup. So share your 11 second combos!
heres one
View attachment 1715285994 69 dart PB 11.35 @ 119.09 MPH, normally mid 11.40's 117 to 118MPH, built to be mainly street driven on pump gas.
Cast iron 340 R3 4 bolt main block @ 4.070
Diamond forged street strip dished pistons #51409
Scat forged rods, mopar forged crank 4" arm
Comp solid tappet 247/254 at .050 107.0 LS
Lift 550/532 with 1.6 PRW rockers and shafts
IMM prepped Mopar LA alumn heads 2.05/1.60
Comp Bhive springs and retainers
IMM prepped mopar alumn. 6 Pack intake
Holley 6 pack set up c/w Promax metering and jet plates
also modified the kill bleed circuits to accept interchangeable
bleed inserts for front and rear carb opening control.
3/8' phenolic carb to intake spacers
Custom machined billet velocity air intake
Sealed to hemi hood as good as possible
SMR built manual 727 --9" converter
Denny's driveshaft, 8 3/4 rear 489 case Trutrac 3.91 gears
Moser Axles
MSD box,coil and distributor.
T T I step headers 3'' exhaust
MT Street radials 255 60R 15"
Made 525 hp at flywheel at 5800 RPM
Tried AED 850 HO and airgap intake for a bit, lost a tenth
Little much maybe--- so back to 6 pack which I enjoy.
For up to about 3500lb race weight, figure on making about 440-450hp, uncorrected, as the motor sits in the car on the starting line.
Cam/converter/gears....... all on the same page.
If I were building it, it would be something like a 10.5:1 stroker, RPM type heads, SFT cam, headers.
I would be targeting 475-500 STP corrected power on the dyno.
That’s based on the assumption you’re not racing at a high attitude track.
My father's AAR went 11.50's with a 402 cu in small block, 11: 1, factory heads, exhaust manifolds, factory exhaust, intake, carbs. Pretty much full weight. Also factory g60 polyglass tires. Six pack setups work pretty well.
When I first had a stroker motor built with a 6 pack, I wanted to see if how the same motor ran with a big 4bbl on the dyno. The results were interesting. Valve train instability(which is evident on the dyno charts) almost cost me the motor, and led me to switch over to a street friendly 10.2 to 1 compression, a custom valvetrain set-up by B3 Racing and I went to a solid roller picked by Dwayne Porter, who found the root of my problem and helped figure a way out of it. The car runs below the 11's, but the information is still interesting.
#3---DYNO TEST 684HP 500CID 6-PACK & 4BBL (J CROSS) 01/2007
WOW. Made more power at 3500 than a stock 440-6 was rated for peak
This is the fastest one I know of.....yes..it is a Legal NHRA Stocker....has been parked for years...This was in 2006
Gene Buell, Hesperia, Calif., '70 Challenger, C/SA, 10.596 seconds, -1.394 (under index)
And that was in Vegas air....
