67Dart273
Got the White Whale III back in the air, I'm considering converting it to a stick. I notice it has a drilled frame "about where" and I go look Google, and sure enough, some of them use a center support/ carrier bearing.
If you have one that uses one, can you measure the height of the bracket between the frame crossmember and the bearing mount flange?
In other words the height of the "support bracket" in diagram
