Anybody running CSR electric waterpump?
pettybludart
Ontario,Canada
Today I removed my edel alumi waterpump for an electric CSR waterpump.What does everybody use for the intake to waterpump hose?Or do you just block off at the intake and at the waterpump?Any pics would help.Thanks for any advise.
Hello I use a CSR waterpump. I did block off the port into the intake and removed the thermostat. I use an electric fan with an adjustable thermostat. I thank you will need to remove the thermostat if you block off the bypass hose into the intake.
I,m not running a thermostat.now that I think of it,with one hole blocked of the second hole is for temp sender for electric fan.Doh!Thanks.
