Because I'm going to use an Edelbrock Performer RPM, I asked Holley Tech Support this question and this was their reply:
[email protected]>
Sent: April 23, 2019 10:48 AM
To: [email protected];
[email protected]
Subject: HLY-000000000201667
Hey Jim,
you could use a blaster 2 coil 8202, we have plenty of customers using the same coil for the same reason as you. As for the intake you will only need to notch it if it goes all the way to the top and t
hat''s just so the map sensor can get signal from both sides of the engine. If you do need to notch it you only need to take about an inch out.
Your Question Was:
We are considering installing a Sniper and Hyperspark ignition on this 340 Mopar and have 2 questions (at least for now!)
1. We want use a round coil rather than the hyperspark coil for a more stock appearance. Can you advise on a suitable coil part number?
2. We are planning on using an Edelbrock Performer RPM intake manifold p/n 7176 dual plane. Will this be ok? Should we cut down the plenum divider?
Thanks
Jim B.
Holley Tech Support is very responsive to answering question about the Sniper and their Forum is also very helpful.
Sniper EFI
