goldduster318
Overzealous Car Modifier
Hi all,
I recently purchased some 18x9 +34 Torque Thrust M Anthracite wheels for my 1970 Duster with the factory 11.75 brake setup. Planning to use 275-35-18 just as 72blunblu did.
Anyway, so I go to test fit the wheels on the front and I find this:
The wheel will not fit down on the hub. This came as somewhat of a surprise as the hub diameter was shown as 2.858" which fits fine on the back, it's just the hub sticks too far into the wheel. Knowing that 72blunblu had suggested a 10mm spacer, looked at how far it's off. Turns out that the wheel depth is only 0.9" to the 45 degree chamfer where it necks down to 2.25" to hold the center cap. The depth at the bottom of the chamfer is 1.2", which is pretty much what I need (1.580 hub height -0.3937 spacer = 1.1863)
So now I'm pretty much faced with sending the wheels back and then trying to find a different one OR machining the hub bore up to 2.75", then using the rocket racing o-ring style center caps to cover the dust cap. I'd probably still have to turn a little bit off the end of the rotor to get it on there.
Would like to hear your suggestions.
Thanks.
Thanks.
