nm9stheham
I am rebuilding the heat/defrost control for my '62 Dart and the issue was that the blower switch contacts inside the control corroded and got hot and made everything all 'melty'. I trimmmed out the plastic button control holes and made the mechanical action all good, but the brass contacts and associated berylium copper wipers needed some treatment for the corossion.
What I am trying for restoration is some silver plating powder called Coolamp from a company in Oregon that has been making this product for years. This is a simple treatment of rubbing the powder onto a burnished contact for 30-60 seconds with a damp rag. You get a thin silver plating as a result. Below is a picture showing the brass contact plates with the contact and connector areas plated, and one of the switch button wipers plated too beside one waiting to be burnished.
For switch grease, I used some silver loaded grease call Cramolin; I don't know if this is even made anymore under that name. My dad (RIP) used this regularly to restore burned relay and switch contacts and connections in high power AM transmitters for years.
After initial re-assembly, the switch contacts were all reading 0.1 ohm or 0.0 ohm on my Fluke digital meter. I'd have to pull out a better meter to get a truly accurate readings.
Coolamp and any silver loaded greases are expensive so this makes sense only if you have it for other things or are doing a a bunch of electrical parts restorations. Coolamp can be bought off of eBay for a lot less than new.
