D downsr Well-Known Member Joined Dec 17, 2011 Messages 885 Reaction score 85 Location waverly ohio May 25, 2015 #1 What do i need to purchase to change the adjustable axles out to the new type axle bearingsin a 70 duster.I believe they are called green bearings.Does someone sell a kit.Thanks
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,968 Location las vegas May 25, 2015 #2 Doctor Diff sells then...old bearing need to be press off..and new bearing pressed on... http://www.doctordiff.com/green-bearings-pair.html And if you want I can sell you a set also ...as I have two sets left over from rear disc brake swap outs They are brand new in the box....55 dollars shipped..via USPS
D downsr Well-Known Member Joined Dec 17, 2011 Messages 885 Reaction score 85 Location waverly ohio May 26, 2015 #3 Thanks but i need them quick.Will try jegs to see if they have them.
