70wayfarer
ok, my shifter arrived today and once opened i realized i need a reverse pattern gate plate as i have reverse pattern VB. on the dyno Monday and wanted to get shifter in before then. got Hurst pro-matic 2 at the moment and it sucks. doesn't select gears properly.
looking at the instructions the plates are the same up to neutral postion, from there it is either D-2-1 or 1-2-D. can i just use the std gate until reverse pattern gate arrives.
http://files.dpbrands.com/bm/instructions/81052.pdf
cheers
cheers
