vestracing
Up for discussion, back the valves off or leave them and rotate engine every week. Putting the dart up for the winter and wanted everyone's thoughts.
Hyd or mechanical? if its Hyd, the lifter bleads down. aka backs off the valve for you. if its a mechanical cam, i would back them off for the winter.
I might be a horrible person...but I just park it most of the time......I always say I'm going to start it once a month, but I might start it once during the whole winter...Not saying its right, but so far it has survived. Every few years I do it right and just pull the shafts.
Having said that, I will probably just pull the shafts this winter. I always get busy doing other things and forget :violent1:
Why can't you just pull the carb and put a cover on the intake ? And block off exhaust ?
You can do whatever you want...LOL
I know that . But will it work are not ? It was a question ,not a statement .
The main reason for backing off the rocker shafts is to save your springs. Having a 500# spring compressed for 6 months is probably not that great for it...it makes sense. A secondary benefit is it seals up the motor.
To the OP, Just back the shafts off slowly and evenly, then put them back on the same way...slowly and evenly (1/4 to 1/2 a turn at a time). This is the only way I have ever put mine on...I don't think I could get the push rods in after installing the rocker shafts.....well, I could...but it would be a PAIN in the 8 3/4....![]()
Change the oil, fog it, drain the block and cooling system, back off the rockers and then back off the shafts. Pack the car with drier sheets, and leave it alone until spring.
