Well, if restriction is a problem, I'm sure Desy will figure it out.As far as pre-filtering
the pump,
a)vacuum is what creates flow from the tank to the pump,something it has a hard
time developing w/"acceptable" chunks of debris trapped in the valving
b)properly placed pumps are low in the vehicle,so losing their prime once flow
is established usually is the result of one thing-running your car out of fuel,
solution?,don't run your friggin car out of fuel!!
c)vapor locking is the result of too much heat in the pump body& line running
over the engine,it matters not what's going on before the pump,as long as it
is that hot any fuel that manages to enter it just boils and perpetuates the
the problem.Solution? cool the pump,better yet protect it and the metal line
from heat B4 it's a problem.W/o an exh. man. hovering above/behind it,
my slanty NEVER vapor locked,even driving to the track for close to 3 hrs.
and waiting in line.
d)all toyota tks w/carbed 22R engs. had the filter at the tank,& the pump on
the cyl.head run off the cam.Road was just littered w/them summertime-
NOT!!
E)500ci caddy,440satellite360rwhp,SB&225darts,455'64olds405rwhp,383Mbody
w/4.89's&nitrous4spd445rwhp.............
OK I'm done
