BIG-B-Barracuda
was driving my barracuda brought it up to TEMP. and i started to smell hot/burned antifreeze coolant popped the hood and noticed the top hose was hard and semi "ballooned" did i over fill my radiator with coolant? is my thermostat not opening? gauge doesn't show overheating holds at 190' which is what i believe my thermostat to be a 190 degrees. :happy1:
do i pop open the radiator cap and let it drain out to proper amount and let the bubbles out?
im lost here these things are usually very simple. :coffee2::burnout:
