diymirage
HP@idle > hondaHP@redline
ok, a proform 750, but pretty much a holley
about a month ago i fouled a fuel filter and in order to make it back home i ran the car without a filter
of course, all the crap that clogged the filter now got into my carb
it wil run fine one moment, then idle really high...i caught her doing that once and i pulled the air cleaner lid just in time to see fuel dribbling down the carb and when i pulled the needle, sure enough it had a bunch of crud in the seat
at times it will stall out when your cruising at idle (i havent figured that one out yet, but i presume it is crud in the idle circuits?) luckily a little tap of the throttle will wake her right back up
at any rate, ive rebuild plenty of 2 stroke carbs but this is my first 4 barrel
my main concern is breaking seals that may need replacing and missing hidden circuits...so what advice can you professionals give me?
