moparspares
I bought one of these from Rock Auto and fitted to my 73 Duster and it leaked. Got a replacement sent just fitted that and it leaks worse than the first one. Not just a slow leak either totally drained the reservoir in less than 24 hours. These are supposed to be pressure tested which cannot be possible. I'm pissed to say the least. Which brands have you had luck with.
No it does not leak from the hoses. Leaks around the housing.
