Anyone have part numbers for main and rod bearings for use on an Eagle crank using Eagle I-beam rods? Clevite or Sealed Power. 76 360 standard/standard. Thanks
Mark
Thanks Kim. Couldn't find them on their website, so I e-mailed them. They replied back within an hour! Clevite ms1051p for 71-73 or ms1266p for 74-93 mains and cb481p rods. Hope this helps if anyone else is looking for this info.
Mark
Unless this is a stock replacement type crank, you will want to run the CB-481HN. Otherwise you may have issues with the radius of the crank hitting the edge of the bearing.
Thanks for the replies. It is a 4.00" stroker crank. I haven't ordered anything yet. The ms1266p's are full groove. I will check the cb481hn's out. The cb481p's say champhered for eagle, mp, and callies cranks. I hoped someone that has just put one together would remember the ones they used.
Thanks again. That's why I like this site so much. I search on here alot and usually find all the info I need without having to ask.
