Mr Gorsky
I know words, I have the best words...
When I purchased my Demon I changed all the usual stuff to make the car reliable...filters, belts, hoses, fluids, etc.
Still, the car seemed to have a squeaky belt every now and then....no matter how hard I tightened them. Tried "Belt Grip" to no avail. My small block has one belt that runs a single pulley alternator, and a second belt to drive the water pump and power steering. I have a three belt crankshaft pulley (one remains unused due to the single pulley alternator).
Well, I found the cause of my issue.....the alternator pulley is off-center! Been that way since 1972, I guess! No obvious damage due to having been dropped, it was just poorly manufactured.
Spotted the problem by revving the engine whilst watching the belts. The belt in question was whipping a full half inch, midway between the crank and alternator. The water pump belt remained rock steady.
Changed the pulley out, problem solved
Pics below detail the issue pretty clearly. The pics are of the same defective pulley taken 180 degrees apart.....check your car, you might have the same problem
