i got the hughes 5321 hyd. roller lifters and custom hughes cam for my turbo build. they state that their cams have fast ramps. i tried the method of setting lifters as per their instructions and found them to be what i thought was quite noisy.
i contacted hughes and was told to get 0 lash and then 1 full turn on the adjuster. did this and still think they are noisy. engine is efi so maybe some injector noise there as well.
also asked them how important it was to use the recommended 10w-30 oil. they said it was not that important but wouldn't use a 15-40 or 20-50. i am using 10-30 for now and is like water when up to temp. will change uo to 10-40 next oil change.
