Since I've owned my car it will start by turning the key while its in gear. Car is a 70 340 4 speed Duster. I know it shouldn't be hard to just remember to put the car in neutral before starting it but accidents do happen. I'd like to make sure all the components are in place and find the issue. It's possible that the tab on the relay has just been grounded to cause it to start in all gears. Can anyone post a pic of the clutch safety switch and its location so I can see if the hardware is still present? Looking under the dash as the pedal assembly I don't see anything that looks similar to the brake light switch and that's what I'm thinking it should look like. Thanks in advance.
