[Found!] Big block 727 separator plate
44o gts dart
iowa
Working on 69 torqueflite, needing a good separator plate. ( mine has pits) the transfer plate # 2801295, valve body # 2892348. I have a small block torqueflite and it is different..Any help or knowledge would be appreciated as always…
Now,,, I have been told that I should try a later (after 72 ) valve body, because of a part throttle kick down … which would help drastically on the street..
I hope I solved the problem, I bought valve body from crt today….
