racerkilla
I have a big block bellhousing. One or two of the transmission bolts needs a heli coil. When cleaning off the grim on the inside where the flywheel is I found a weld 3 inches long. Looks like it might of fixed a crack way back in the day and did a good job. From the outside of there is nothing. Never noticed it until today
Original 10.5" big block bellhousing to fit 383 67-9 A-body Barracuda/Dart and 383 1966-7 B-body (will also fit 1965 B/C- body) cast #2468372, 4.354" bearing retainer diameter, use with 130 tooth flywheel.
Looking to get 175 plus actual shipping for it. I am in Jeffersonville NY 12748. I will get pictures up tomorrow of it.
pics of bellhousing and weld
