[SOLD] Big Bolt pattern axles etc 7.25
azmopar
rust free parts guy
goodyear az
have a set for big bolt pattern axles brakes and drums, for a 7.25.
if youve converted the front to bbp pattern disc brakes and dont want to carry two spares?
dont have the cash layout for the 8 3/4?
bolts right in same brakes and drums as the 8 3/4, big bolt pattern
axles with studs and bearings, drums and a set of loaded backing plates(shoes and all hardware including the emergency brake cables to the first connector .
$100 bucks gets it all plus shipping from 85338
7 1/4 housings have two different housing ends.
Small bolt pattern housings have 4 studs to mount the brake parts,and retain the axles, and large bolt pattern housings use 5 studs. Also the large bolt pattern axles use larger bearings, which will not fit into the sbp housing.
Just trying to help.
Well they slide in the 4 bolt housings I have. Yes I know about the 4 bolt and 5
