Pentastarnut
67' Barracuda
anyone try these ?
http://www.cvfracing.com/Chrysler-Small-Block-Pulley-Kit-PS-p/scrl2kit.htm
thankstheir crank pulley is 5.2" in diameter. so it is a little bit under driven...i think the stock crank pulley is around 6 inches in diameter...
What is the negative, if any, on running underdriven pulleys? Alt voltages, cooling issues maybe?
Anybody happen to know if there are any SB/BB pulleys that are the same as a slant 6 ???
CVF makes very nice, high quality pieces in my experience....and they're substantially less $ than the March competitors. They are slightly underdriven and i asked their customer service a few questions and the responses were clear concise and quick i will be purchasing a set shortly:mrgreen:
That is a big question. Since they say 70+, must only work with an aluminum water pump, which sticks out ~1" further than the earlier cast-iron one. Even then, I understand the crank dampers vary in thickness, both stock and after-market. I think the pulleys also came in many variations whether AC, pwr steering, etc.... if they fit and line up that is a great deal
