j440b
Anyone have experience using a bolt on timing chain tensioner?
Looks like it would be helpful for stable timing.
It would seen to me that "That side is always tight.".......only if the engine is running backwards. I've installed a few of them.That side is always tight.
No, the drivers side is tight because the crank is pulling it. That’s Y the tensioner is on the pass side to take up the slack. KimI thought the pass side would be tight with engine running? I've got gears spinning in my head![]()
I agree.the tensioner was designed to be used with a factory "silent" type chain.
I used one on my 5.9 magnum build. I used an aftermarket double roller chain with it. I pulled that engine apart to swap the cam and found that the tensioner was pretty chewed up.
I think the tensioner was designed to be used with a factory "silent" type chain. I didn't and won't use one again.
"That side" is referring to the pull side not the loose side where the tensioner goesIt would seen to me that "That side is always tight.".......only if the engine is running backwards. I've installed a few of them
I have had a tensioner fail and chunks of plastic get between the chain and gear shearing the pins holding the links together.I'm happy with that as I've never had a tensioner fail
We are going to belt drive with a crank trigger ignition. Distributor on the front of the cam. I'll have a nice billet cover for sale when it comes off. My son is going to start making them on a CNC.There is a reason why real performance engines use a belt or gear drive.
I find it a bit odd that guys will spend thousands of dollars on a great engine and then cheap out on a 150 dollar timing chain.
Just cRaZy IMO.
Thats stepping over donuts to pick up dog turds.
Haha, hey it works...If you really want to whack the bee hive ask about how to oil the chain!
I've heard many an old fart claim gears are a time bomb despite all of your heavy duty and medium duty diesels using gear drives. Yes the Cummins dowel pin and all but when built properly a gear drive will last forever and never lose time.There is a reason why real performance engines use a belt or gear drive.
Just cRaZy IMO.
My brother had one on his 408 and my currently has one on his that's sitting on an engine stand.Anyone have experience using a bolt on timing chain tensioner?
