The center section is held in by nuts off studs that are pressed into the housing. Axle retainers are off studs too...What bolts are you speaking of? Maybe 8.25?
I was told by Dr Diff that the Mopar housing studs are no longer available; however, Ford 9 in studs are an acceptable substitute. He has the correct axle end studs.
