OEM brakes on a 73 Duster. Power brakes not acting like they should. What should be the adjustment setting be for the push rod? Booster checks out, vacuum and valve is fine.
Just need to do a final check on the gap for the rod. I've seen where the gap should be .020", just not sure if this is correct.
Thanks and be safe out there. Jack
