Bostonian 71 demon
@1bad360duster so you do not agree about the magnesium D60 in Motowm missle? Taken directly from the book..
Haven't posted in a bit but, I've collected some new hemi parts including a brand new set of stg V dual plug heads. Also took the car to the Kansas City World of Wheels
New oil pan came in and I pulled out the old bucket seats an went with a one piece high back bucket
@B.R.E.Demon
What's the latest on the car????
So, We did a bit on the car Post PRI and took it to an event were I damaged the Doug Nash on the 3rd gear shift. So we pulled it and fixed it I then had to turn my attention to my C10 as work at the time needed it for R&D and I had to finish the 383 build to do so. Once that was done (skin of my teeth) I had to focus on our move to Colorado as my wife's Air Force job required it. So the fixed car went on the back burner to get that done. In that time I had to change jobs with in the industry and jump over to Cam Motion which has required a lot of travel too. Now as things have settled I'm Turning my focus more towards the HEMI! (post will outline that). But as of right now the car is being taken apart and parted out to facilitate the Pro stock build. The small block is going, parts of the cage is being redone, tubing the car, all the bolt on panels will be fiberglass now the inner fenders are coming out (replaced with aluminum) Going with a rack and pinion and coil overs. new rear brakes. filling the cowl, glass cap and marker lights. obviously a repaint. The car when done will be almost 100% visually the same but brought up to the 98% authentic of an early Pro-stock (not acid dipping the body) but my wife and I plan to have it done for October of next year (2025) to facilitate our obligations to our sponsors( not saying we
re but do the math on debut) I will say this : the car is going no were Im just taking all my knowledge and experience from time within the industry and racing to build the best version possible.
MCACN 2025 would be a great place to debut..IMHO..
Nice work. Thanks for thr update.
Now For the Hemi! The motor is being assembled with parts coming from quite a few sponsors with the intention of having the engine running and Dyno'd for this November to have ready for the trade show. We have B.E.S. doing the heads and intake and the valve job on the titanium valves. I'm doing a 60mm core custom solid roller through work(Cam Motion) in the engine lifters 1.000 od .920 wheel Pro Stock Jessel pieces. Plus I Got a set of Manton's Top Fueler rockers and shafts plus using their pushrods. The Crank is now a winburg billet piece with CP Carrillo Aluminum rods and Arias Pistons. Still doing 14.5:1 and picked up a fully built and modified A833 four speed and got on order a triple disc black magic clutch. Dispite All the new school tech the engine will maintain its nostalgic appearance to fit the retro build of the car.
So last night I stated to tare down the car to sell the motor and then the sheet metal. Plus started to do research on acid dipping.
