Brake line question
pishta
I know I'm right....
Tustin, CA
OK, so I got this Disk/drum M/C, all is good, but...See the little inverted flares? I bought some brake lines in 20" lengths to connect to the combo block, but may have erred on the size. I bought the 1/4-20 and the 5/16-20 lines to match the Mopar dist block (front and rear are different) but the inverted flare in each port is the same size, tiny..like 3/16, the same size as my original '65 lines, way smaller the the ID of the flare in the new lines. So...do they make an adapter to adapt the 3/16 inverted flare to a larger 9/16-18 and a 1/2-20? Imagine an almost solid 1/2-20 with a tiny 3/16 flare in the male end and then a female end that has the normal 5/16 inverted flare. Am I going to have to go with a stack of adapters or maybe just double flare some 3/16 line with the nuts that will fit the M/C? What I really need is 2 20" sticks of 3/16 line with 9/16-18 nuts on one and 1/2-20 on the other...didnt see those hanging up.
