break in oil vs break in additive
duster wonder
National Guard Member
WI
yay for another discussion
6 quarts of pure break in oil ooorrrrr...
5 quarts of "regular" oil plus one quart break in additive
price??
comps oil 6 quarts $34
additive $10 plus "regular" oil = $35 give or take
so what does ur brain think? :protest:
my brain say use 20-50w castrol gtx and a bottle of stp like i did on my last fast rate engle solid cam, no problems.
or run schaeffers oil all the way @4.75 a quart.
i dont use the out of the ordinary break in lubes everyone touts
I Have comp cam (thumper) and comp cam lifters, used Comp Cams break in oil, 10w-30 no problems. Got it from Jegs $7.99 quart
the reason i say comp oil is so i can keep the warranty for a comp valvetrain..
and a quart of comp oil is 5 smacks on summit
At a minimum use Mobil Delvac 15/40W it still has a decent ZDDP content level along with a bottle of breakin additive. Don't cheap out on this critical step. Why even chance it ? Personally and professionally I use the breakin oil every time. Cost is virtually a wash after you shell out $10-$12 for additive on top of $22-$25 in regular oil vs $36 for breakin oil.
Does anyone know if that Shell Rotella T oil from canadian tire has zinc in it still? It says for diesel and heavy gas engines. Might be something to look into. I used that comp break in oil too on my 440. Says only run for 500 miles on the bottle for some reason, so I strayed against using it for regular use.
I did a lot of oil research after my build and couldn't get a comfortable feeling about the zinc content in shell or anything else conventional for that matter so I went with the Brad Penn oil (they also have break in oil). Where I am though it seems like everyone uses the Lucas break in oil additive without any problems.
