67GTConvert
Hey guys,I recently bought a GY3 71 Dart Custom off another member here,which is kind of unusual in more ways than one,and it came with two broadcast sheets which are different and really interesting.I'll post what I know and what I think then I'm hoping some of the experts on here could hopefully chime in and agree or disagree then answer a couple questions I have about them.
First off,what I know about the car is it's a 71 Dart Custom VIN LP23G1R100068,which,as most of you will know,will be a 2DRHT with a 318 and I believe would be 68th 1971 model released for production for the Windsor plant so it was destined to be an early build.It has an order number of M00101 which,IIRC,the "M" is an internal code for a promo car.Given the unusual color and the number of trim options (for an A-body at least) and that it's also coded for a Y93 show car finish,this seems like a possibility.Am I on the right track with that theory?
What's also interesting is that it came with two build sheets which are different in a several ways.First,one sheet is a conventional colored sheet and is the same as the other for the first 6 areas except for two things,the sequence number is different (#000090,preceded by a 3) and there's a code missing for the RH front brake (RH front brake delete car? lol).When you get to line 7,the computer goes full Windows and spits out a bunch of codes in a row starting in the Heater A/C section then into the Glass area that make no sense.No idea what the codes are for.There's nothing else in the lower areas where there should be codes until the comments section at the bottom where the top line is double typed in places but if you read carefully,it's the first two lines of data for the build sheet of the next car in sequence (#000091,also preceded by a 3).It's kind of cool car,71 Satellite 2DRHT 383/auto in B5 blue with a white canopy top with a blue interior.It's VIN number ends in 100137 which shows the VIN numbers aren't built anywhere near in sequence on the line.
The second build sheet is also interesting.First,it appears to be a black and white photo copy of a correct build sheet and it's on much heavier paper than the colored sheet.I didn't even know they had photocopying back in 1970 so this is news to me and I've never seen another broadcast sheet like it before.Anyone else on here seen one of these?
This sheet seems correct in regards to all the codes and what not but the sequence number is now #000003 and preceded by a 1.Anyone know why the number preceding the sequence number changes from 3 to 1 (or visa versa)? Is that an assembly line number,maybe?
Also,any guesses on which sheet might be the "final version" with the correct sequence number? Would it be car #3 down the line or #90?
Another thing is in the comments section there's a typed note "88 NO BODY PLATE BROADCAST".I'm guessing that what they call the body plate is what we usually call the fender tag?
The car has no fender tag and doesn't appear to ever have had one so maybe that explains it.Anyone else ever seen that on a build sheet on a car with no fender tag?
It also has "U S A EX-FACTORY 8-21" hand written in the comments section.Any idea what that means? The car was built to USA specs,exported to the US and sold new in the mid-west.
I'll post pics of both sheets shortly.
